Power Seat Fuse Issue (Drivers side 2004) C230
Yet another problem .......
My drivers seat lost all power function. I checked the fuse in the box located in the trunk and it was blown. I replaced it and things worked fine for about a month, until recently when it blew again. I replaced it yet again and this time it only lasted about a week. Im assuming the issue is more than just a fuse???
Any help or sugestions would be much appreciated !!!
RE: Power Seat Fuse Issue (Drivers side 2004) C230
You have a short somewhere in the wiring. Could be a pinched wire and when the seat moves to a certain position it blows a fuse. Start with the wiring under the seat, I'll bet you find a wire with some worn insulation that is pinching or rubbing on metal when the seat is moved. Thus blowing a fuse.
I checked all the wiring and nothing seemes worn. The rear heating vent was covered by the floor mat so perhaps the heat may have caused the blown fuse?? I replaced the fuse with the passenger seat fuse(still stock) and replaced that with one i picked up at the local auto store. Hopefully that will solve the issue. For now I'll just have to wait it out to see if the fuse blows again.
