Wheels/Tires Need custom rims? Have a tire question? Come in and let's talk.
Proper Tire pressure - larger diameter wheels
Old Jan 29, 2010 | 01:50 PM
jimmymac's Avatar
Default Proper Tire pressure - larger diameter wheels
I have a 2007 SL550. I replaced the original wheels and tires with new, larger ones. The newer tires have shorter sidewalls as well. What tire pressure should I use? Should I go with the car's recommended 30/33psi front/rear, or something else? I already hit a pothole and pinched the sidewall on one of the front tires which I need to replace. Could this be due to tire pressure that was too low?
Original tires
front 255/40-18
rear 285/35-18
New Tires
front 245/35-20
rear 275/30-20
Old Jan 29, 2010 | 07:32 PM
TireCrawlerNikki's Avatar
The air pressure will not change. With the load indexes 97 and 95 the same, the air pressure remains the same.
Old Jan 29, 2010 | 08:35 PM
jimmymac's Avatar
Not sure how the Load Index relates to tire pressure. I didn't know if the fact that the new tires have a larger diameter and a smaller sidewall might mean that they should have a different pressure. Also, if the automobile specifies 30psi and the tire has a maximum psi of 51psi, am I OK with any pressure in between the two?
Old Feb 1, 2010 | 12:15 PM
The load index refers to the amount of weight a given tire can carry at different air pressures.
Inflation Pressure (PSI)
Load Index
26
27
28
29
30
31
32
33
34
35
36
95
1235 lbs
1272 lbs
1290 lbs
1345 lbs
1400 lbs
1455 lbs
1510 lbs
1530 lbs
1530 lbs
1554 lbs
1609 lbs
As long as the tire you went from is P metric to P metric tire or European metric to European metric the air pressure, in theory, will remain the same when the load indexes haven’t changed. I’m pretty sure that you have Euro-metric sized tires.
P metric tire starts with a P, for example P255/70R16, and the European metric doesn’t have the P at the beginning of the tire size (255/70R16).
Old Feb 1, 2010 | 12:23 PM
Hmmm, those didn;t turn out the same when I posted them before, lets try those again!
Load Index 26 27 28 29 30 31
95 1235lbs 1272lbs 1290lbs 1345lbs 1400lbs 1455lbs
32 33 34 35 36
1510lbs 1530 lbs 1530lbs 1554lbs 1609lbs
hopefully it works this time!
Old Feb 1, 2010 | 12:24 PM
well, its just not working to post that stuff here. Sorry!
kents
Mar 3, 2012 10:09 PM
Chargerfan
Dec 3, 2009 04:59 AM
strelnik
Dec 23, 2007 06:56 AM
nick kate
Apr 8, 2007 03:04 AM
kevinrea
Aug 17, 2005 05:16 AM
