Wheels/Tires Need custom rims? Have a tire question? Come in and let's talk.
Directional Tires???
Old Oct 20, 2011 | 06:04 PM
Thumper75077's Avatar
Default Directional Tires???
I recently purchased a C230 and the tires are wearing thin in the outside. Someone told me this is due to the way Mercedes sets up the suspension to run on the autobahn. Makes sense to me, but they also said the tires were directional so i could not rotate them OK it's possible but I didn't think they were. Are these things set up with directional tires?
Thanks in Advance
Thumper75077
Old Oct 20, 2011 | 07:18 PM
chassis221's Avatar
worn shocks, struts, bushings, tire pressure, tire load rating can contribute to tire wear, your tires should wear evenly.
there are directional that will say INNER and OUTTER on the wall of the tire and also tires that will have an arrow pointing in the direction of travel.
if you have the same sized tires all the way around the car then you can swap them, just be sure the directional tires are going the correct direction.
BlueSilver
Nov 21, 2011 09:53 PM
stevesdig1
Feb 11, 2010 01:11 PM
mlauto
Oct 25, 2007 05:40 PM
chiro
Aug 9, 2006 02:55 AM
chiro
Aug 6, 2006 02:53 PM
