Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
W203 Tech - Belt Tensioner Issues? Parts In Stock Now! by Pelican Parts
Old May 15, 2013 | 12:40 PM
PelicanParts.com's Avatar
Sponsor
Default W203 Tech - Belt Tensioner Issues? Parts In Stock Now! by Pelican Parts
The V-belt tensioner provides a constant tension on the belt which is needed to run all of the engine accessories. Over time the tensioner can fail to maintain the proper tension and the belt will start to slip. If this happens it will usually make a squealing noise. The tensioner can also fail by the bearing wearing out - this will cause the belt to wear unevenly and fray along the edges. You should check your tensioner and V-belt every six months for wear, cracking, fraying, delaminating and drying out. If the tensioner is loose or you can wiggle it or if your belt shows any of these signs you should replace them.
Shop now for replacement belt tensioners for your W203 car - Click HERE
Tools required: E10, E12 Torx driver
Applicable Models:
C320 (1998-2004)
E320 (1998-2004)
S320 (1998-2005)
ML320 (1998-2003)
CLK320 (1998-2004)
SLK320 (1998-2003)
This project takes about an hour.
Pelican Parts
PelicanParts.com
Jul 3, 2013 11:31 AM
PelicanParts.com
Jun 17, 2013 12:59 PM
PelicanParts.com
Jun 5, 2013 12:46 PM
PelicanParts.com
May 8, 2013 11:50 AM
PelicanParts.com
May 2, 2013 06:57 PM
