Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
Ready For That Alternator DIY? We Have Your Replacement Ready To Ship!
Old Oct 7, 2013 | 04:25 PM
PelicanParts.com's Avatar
Sponsor
Default Ready For That Alternator DIY? We Have Your Replacement Ready To Ship!
The alternator charges the battery and provides your car with a constant source of electricity while the engine is running. Over time, the alternator can fail and cause problems with other electrical devices in the car.
The first thing to check is the battery light on the instrument cluster. This light bulb is part of the alternator field circuit; if it burns out the alternator will not charge. Simply turn the key on and see if it illuminates briefly then goes off. If the light does not illuminate, you’ll need to replace it before continuing.
Inspect the belt that drives the alternator. Is it tight and amply turning the alternator? If not, then check the condition of the belt, they seldom break, but they get brittle and glazed with age, and can slip on their pulleys. Replace the belt with a new one as required.
The next item to check is the voltage at the battery. This should read a little more than 12 volts with the engine off. Wait two minutes after starting the vehicle for (accessory cycling) voltage to stabilize. When the car is running, the voltage must read in the range of 13 to 14.5 volts with the engine at 3000 rpm.
Finally, check the ground strap itself and make sure it is connected and not damaged.
After checking the above and you’re still experiencing charging issues, it is likely the alternator will need to be replaced.
Shop rebuilt alternators from Genuine Mercedes-Benz & Bosch here.
Mark/Pelican Parts
PelicanParts.com
Feb 6, 2014 07:25 PM
PelicanParts.com
Oct 25, 2013 11:25 AM
PelicanParts.com
Aug 12, 2013 02:14 PM
PelicanParts.com
Aug 2, 2013 06:30 PM
PelicanParts.com
May 22, 2013 07:08 PM
