Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
Change Your Front Brake Pads In A Snap! By Pelican Parts
Old Oct 10, 2013 | 11:31 AM
PelicanParts.com's Avatar
Sponsor
Default Change Your Front Brake Pads In A Snap! By Pelican Parts
Replacing your brake pads is one of the easiest jobs to perform on your W203 Mercedes-Benz. In general, you should inspect your brake pads about every 25,000 miles, and replace them if the material lining of the pad is worn down enough to trigger the pad replacement sensor or there is less than a quarter inch of material on the pad.
You can change the front pads on your W203 Mercedes in less than two hours and save some dough at the same time!
Shop pads HERE from brands Genuine Mercedes-Benz, Pagid, Ate, Textar, Bosch, Akebono, Jurid & Epad from Textar.
Let us know if you need instructions to assist you with the installation!
Mark/Pelican Parts
PelicanParts.com
Sep 20, 2013 06:55 PM
PelicanParts.com
Aug 27, 2013 12:27 PM
PelicanParts.com
Jul 25, 2013 12:22 PM
PelicanParts.com
Jul 8, 2013 11:08 AM
PelicanParts.com
Jun 21, 2013 06:54 PM
