Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
Fuel Injectors On Your E320 Performing Poorly? Parts Available Now!
Old May 30, 2013 | 01:39 PM
PelicanParts.com's Avatar
Sponsor
Default Fuel Injectors On Your E320 Performing Poorly? Parts Available Now!
Inside each fuel injector is a small needle valve called a pintle valve that tends to wear down due to repeated cycling. As it wears, it can cause fuel to leak between the valve and the sealing surface. Sometimes, fuel injectors can be cleaned; restoring performance and fuel economy back to stock levels. This is done by ultrasonic cleansing, using sound waves to break up the small bit of dirt and corrosion on the pintle valves. If the injectors are beyond cleansing, then replacement is your only option.
If your injectors can be cleaned without replacement, it is a good idea to install new 0-ring seals at both ends. Find your application HERE within our comprehensive parts catalog.
Let us know if you have any questions!
PelicanParts.com
Jul 23, 2013 03:22 PM
PelicanParts.com
Jul 8, 2013 11:08 AM
PelicanParts.com
Jun 14, 2013 11:45 AM
mymymy
Jan 19, 2008 06:56 AM
medisnl
May 30, 2006 09:02 AM
