Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
W210 Front & Rear Rotors & Pads Available Now! by Pelican Parts
Old Jul 8, 2013 | 11:08 AM
PelicanParts.com's Avatar
Sponsor
Default W210 Front & Rear Rotors & Pads Available Now! by Pelican Parts
Replacing your brake pads is one of the easiest jobs to perform on your Mercedes-Benz. In general, you should inspect your brake pads about every 25,000 miles, and replace them if the material lining of the pad is worn down enough to trigger the pad replacement sensor. In reality, most people don’t inspect their pads very often, and usually wait until they see the little brake-warning lamp appear on the dashboard. It's a wise idea to replace the pads, and inspect your discs as soon as you see that warning lamp go on.
If you ignore the warning lamp, you may indeed get to the point of metal on metal contact, where the metal backing of the pads are contacting the brake discs. Using the brakes during this condition will not only give you inadequate braking, but will also begin to wear grooves in your brake discs. Once the discs are grooved, they are damaged, and there is often no way to repair them. Resurfacing will sometimes work, but often the groove cut will be deeper than is allowed by OEM specifications. The smart thing to do is to avoid this problem replace your pads right away.
We have pads and rotors in stock ready to ship from brands such as Genuine Mercedes-Benz, Zimmermann, ATE, Balo, Fremax, Textar, Pagid, Bosch, Akebono and Jurid.
You can shop our catalog by entering your W210 vehicle’s year here.
Let us know if you'd like install instructions for this project and ask questions at any time!
PelicanParts.com
Aug 10, 2015 05:55 PM
PelicanParts.com
Sep 11, 2013 05:02 PM
PelicanParts.com
Jul 23, 2013 03:22 PM
PelicanParts.com
Jun 14, 2013 11:45 AM
seitz729
Nov 28, 2006 03:40 AM
