solution for poor performing gargare door opener
Old May 30, 2006 | 08:35 AM
medisnl's Avatar
Default solution for poor performing gargare door opener
06 350slk, very poor distance performance from the built in gargage door opener. Seems MB thickened the windshield to improve sound deadening etc. Had to be pretty close to the door
for the unit to make the door go up (pretty frustrating). The fix (since MB had no answer) was to attach a piece of speaker wire to the antenna on the garage door opener, run the wire to hang just outside the garage door (to the front of hte house), the opener unit in the car
now works far away as it should.
Old May 30, 2006 | 08:57 AM
sleepwalker's Avatar
Default RE: solution for poor performing gargare door opener
ingenious.
maybe the reciever on the garage door opener is weak... not on the car transmitter.
Old May 30, 2006 | 09:02 AM
medisnl's Avatar
previous car was 04 slk320..........door opener worked just fine, and ohter car is honda ridgeline and works just fine from that vehicle, absolutely only change in the formula was the new
06slk350, no other variable
PelicanParts.com
May 30, 2013 01:39 PM
sbeemish
Nov 5, 2005 02:44 PM
SLK320Chic
Sep 29, 2005 04:44 AM
fay3131
Sep 27, 2005 10:58 AM
riz
Dec 17, 2004 03:19 PM
