Other Post discussion on all other models not listed above here.
Engine Shake
Old Aug 3, 2006 | 07:46 PM
danpayton's Avatar
Default Engine Shake
81 300SD Turbo Ive got an engine shake that happens only sometimes. I'll pull up to a light, and sometimes it idles just fine, others it shakes the whole car.
Im not talking about a vibration - but the engine just shaking on its mounts and rocking the whole car a bit.
Ive already changed all the fuel / air filters, and run some stanadyne injection cleaner directly into the pump, but it stll does it.
If i adjust the idle up to about 900 - 1000 rpm it goes away - but thats not really an idle
and when its shaking sometimes, i can put it in neutral and rev the engine lightly and it goes away, but not always.
it always idles just fine in the morning but after I take a few trips, or drive for 20 miles or so it will start to do it.
I looked around the forum a bit - but didnt come up with anything
What should I check? I'm at a loss for things to try here!
thanks!
-Dan
Old Aug 5, 2006 | 06:33 PM
carnut's Avatar
Default RE: Engine Shake
This question should be in the diesel forum. problem could be the rack dampner inside the injector pump.
dmfb
Apr 14, 2008 02:19 PM
zanybrainy
Jul 7, 2006 11:53 PM
noslowturbo
Jan 17, 2006 05:43 PM
rmt6668
Jan 15, 2006 08:23 PM
packboy01
May 27, 2004 11:01 PM
