Engine Shake
81 300SD Turbo Ive got an engine shake that happens only sometimes. I'll pull up to a light, and sometimes it idles just fine, others it shakes the whole car.
Im not talking about a vibration - but the engine just shaking on its mounts and rocking the whole car a bit. Ive already changed all the fuel / air filters, and run some stanadyne injection cleaner directly into the pump, but it stll does it. If i adjust the idle up to about 900 - 1000 rpm it goes away - but thats not really an idle ;) and when its shaking sometimes, i can put it in neutral and rev the engine lightly and it goes away, but not always. it always idles just fine in the morning but after I take a few trips, or drive for 20 miles or so it will start to do it. I looked around the forum a bit - but didnt come up with anything What should I check? I'm at a loss for things to try here! thanks! -Dan |
RE: Engine Shake
This question should be in the diesel forum. problem could be the rack dampner inside the injector pump.
