Other Post discussion on all other models not listed above here.
'93 190e speed dependent noise/vibration...
Old Aug 17, 2004 | 08:27 PM
neobopr's Avatar
Default '93 190e speed dependent noise/vibration...
... when straight and also during curves to left. Please help, No noise when I am going around a right curve. Checked wheel-wells thoroughly and no contact points anywhere. Was expecting them on right side. Wondering if it is a bushing gone bad. Car has 135k miles. Any ideas?
Old Oct 21, 2004 | 06:49 PM
MercedesMan300D's Avatar
Default RE: '93 190e speed dependent noise/vibration...
my suggestion would be to jack up all the tires and check them for noise
jack up the frount passengers side first, and spin the tire (as fast as you can without giving yourself a hernia). after that, grab the tire and see if it has any play it it (shake it from side to side, if its alot of movement, or makes alot of noise, its the wheelbearings, and they need to be checked by a professional, repacked, or replaced)
Nate
Old Oct 24, 2004 | 05:18 AM
jome's Avatar
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step.
A great help, hope this will help you.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Jan 5, 2005 | 02:16 PM
neobopr's Avatar
Thanks for your help! Jacked it up and shook...definitely the wheelbearings.
Jaycodyp
Oct 27, 2009 12:57 PM
CARCAR
Aug 31, 2007 10:06 PM
trades1
Jan 13, 2007 10:19 AM
jnash
Feb 11, 2006 11:40 PM
