Other Post discussion on all other models not listed above here.
'85 300TD Vacuum???
Old Aug 20, 2004 | 12:56 PM
JoshuaJeeper's Avatar
Default '85 300TD Vacuum???
I think I might have a few vacuum lines mixed up because I can't get it to shut off properly (have to use the fuel shut-off valve) and can't lock the doors properly either.... I spent hours trying to find diagrams online and attempting to read the one under my hood, but to no avail... Can anyone help with a diagram, or if someone just knows where those bloody wires go... The only hoses I can't figure out are the ones coming through the firewall and into the vacuum mesh.. The rest seem to go where they're supposed to...
Thanks...
Old Aug 20, 2004 | 11:14 PM
sleepwalker's Avatar
Default RE: '85 300TD Vacuum???
send your VIN number.
Old Aug 20, 2004 | 11:21 PM
WDBAB93C7FF048690
Old Aug 21, 2004 | 12:59 AM
i'll send you the jpeg file attached after 2 days. am still on 2 days off for weekend.
Old Aug 24, 2004 | 06:20 AM
i have deleted the image due to legal reason. if you need it, ask again.
Old Aug 24, 2004 | 06:26 AM
Old Aug 24, 2004 | 06:28 AM
Old Sep 14, 2004 | 03:46 AM
blackisbest's Avatar
Can you send that vacuum diagram?? I have an 83 300 TD that has the auto locks disconnected cause I can't find the leak.
Any tips on vacuum line leak finding?? Can you pressureize vacuum lines and use soap solution on the joints??
Old Sep 14, 2004 | 06:07 AM
  #9
sure, send me your VIN number.
joshuajeeper is a jeepers creepers because he didn't even bother to thank me after all the troubles i been through on his favor.
what you need is a vacuum diagram inside the car....right? power locking? specify it.
checking the vacuum needs vacuum handpump.
Old Oct 10, 2004 | 06:51 PM
  #10
Sorry about that Sleepwalker... I've had no internet access for a while, but I'm back up again.. and thank you for your help... I realized that I had all my lines set up correctly but I was about 20psi lower of what I need according to the shop manual and my vacuum pump was barely working.. The piston has almost complete blowby in the pump so I went out and bought an electric vacuum pump and put a "dud plate" over the old spot and the problem is now fixed... It also gave me 2 more HP by taking off the mechanic pump... Sometimes bad things turn out to be a good thing...
geoffscott
Jul 16, 2011 12:39 AM
UKMercNut
Dec 17, 2008 12:24 PM
chaz13
May 10, 2004 12:57 PM
riverratss563
Nov 23, 2003 02:43 PM
tbailey
Nov 16, 2003 02:27 PM
