Other Post discussion on all other models not listed above here.
81 300SD Turbo Boost Adjust....?
Old Jul 31, 2006 | 09:02 PM
danpayton's Avatar
Default 81 300SD Turbo Boost Adjust....?
Ok... So i hooked up a pressure gauge before i did anything (see pic)
Adjusting what "looked" like the BOV one or 2 turns in either direction did nothing (see pic)
So then I realized that the Wastegate needs to be adjusted... But there isnt any adjustments that i can see... Soo I did something tha I KNOW shouldnt be done...
I unhooked the wastegate hose form my tee.. and pugged the tee so my gauge still worked. then brove it about 3 blocks to see how much PSI i'd get. It got up to 21PSI. Knowing the sin that i Had commited I hooked it back up Correctly before I drive back home.
SO what do i do here? I want more Boost! dont get me wrong... im not racing this thing... I just like to make improvements to things by adjusting whats available on the car :^) Ive heard more boost and adjusting the ALDL SLIGHTLY can make a difference...
any thoughts?
oh.. and i put on an "ultra spiffy" intake system.. (see pic)
PVC pipe and a coupler with a cone filter.
Thanks in advance for any ideas!
-Dan
Old Aug 2, 2006 | 02:29 PM
danpayton's Avatar
Default RE: 81 300SD Turbo Boost Adjust....?
Nevermind! i searched the forum and found all the info i needed
thanks!
-Dan
Old Jun 24, 2011 | 01:03 AM
samcoady65's Avatar
could you post a link to what you found thanks
omoorfe
Nov 13, 2010 07:15 AM
ziggytwizzer
Nov 16, 2008 09:46 AM
davesdiesel
Jul 18, 2007 02:42 PM
Asild
Mar 9, 2004 03:42 AM
imi-amg
Aug 29, 2003 08:23 PM
