Other Post discussion on all other models not listed above here.
190E 2.3 16 v
Old Mar 21, 2005 | 12:18 AM
hondah8n's Avatar
Default 190E 2.3 16 v
im new to the forums, just wanted to know where to find a 2.3 16 v motor for my 86 190e. are there any other motors thatd fit? links would be great? what am i getting myself into with a swap? i come from the land of 240sx and swaps arent to complicated. is this swap pretty straight forward?
Old Mar 21, 2005 | 03:40 AM
dbenz's Avatar
Default RE: 190E 2.3 16 v
Try ebay or junkyards for the 16V engine. There are other motors that will fit, but you need a transmission to go with it. You could go with a 2.6 engine also. You could go with a 300E engine which is basicly the same as the 2.6, but its bored out. But I recommend a 2.6 or 300E transmission with all that. If swapping to any of those you will need all the electronics and etc.
Old Mar 22, 2005 | 01:21 AM
hondah8n's Avatar
electronics as in ecu and harness ect.
Old Mar 22, 2005 | 05:59 AM
dbenz's Avatar
ORIGINAL: hondah8n
Yeah you'll need the Bosch CIS fuel injection system, the ECU, fuel pump relay, and the R/16 switch.
Old Mar 23, 2005 | 01:05 AM
hondah8n's Avatar
awesome! thanks so much
harryi
May 2, 2010 02:36 AM
galla900
Feb 12, 2008 10:10 PM
