E320 Electrical Problem
Old Mar 7, 2008 | 12:40 AM
darvish's Avatar
Default E320 Electrical Problem
Any body knows the possible causes for back up light in 98 E320 not working? Non of my back up lights come on when I shift the gear to reverse. I checked all the bulbs and they are fine. I do not beleive the fuses are bad. Is the back up light switch located on the transmission or some where else? I took apart the middle compartment by the gear shift apart but the only switch I see thert is RP valve. I apprecaite any hlp to diagnose the problem.
[align=left] [/align]
Old Mar 8, 2008 | 05:17 AM
MASTERBENZ's Avatar
Banned
Default RE: E320 Electrical Problem
The backup light switch is part of the ESM (Electronic Shifter Module). Did you check to see if you have voltage at the socket? If so, then chances are...your problem is the ESM...
take care,
-mar-
darvish
Mar 2, 2008 08:07 PM
BenzoDJ
Jul 10, 2007 10:09 PM
DRPruitt
Jun 26, 2006 03:38 AM
mwfcpa
Oct 24, 2005 04:21 PM
