steering, suspension or break problems
Old Jun 29, 2006 | 04:57 PM
juanpablo's Avatar
Default steering, suspension or break problems
hi
i have a 2004 slk 230k and some miles ago i have been having problems, the thing is when i am doing like a 120 km/h and a push the break the sterring or something like vibretes, i allready have do some thins and the problem stills and i dont know what eles to do
things done
disk rectifi with new breaks
suspension check and tie on all knots also i they have check all the suspension rubbers and links
the steeering amortiguator was liked so i put a new one
and the second question is , i feel the steering wheel with a little loose in the center its it normal (feels a litle tick tick going one way to another )
thanks for the help
Old Jun 30, 2006 | 03:06 AM
snanceki's Avatar
Default RE: steering, suspension or break problems
Hi.
Sounds like something is loose. need to find cause immediately.
Steering box is known to come loose from body work. Check torque on bolts.
You don't state mileage. What condition are your brake rotors in?
Do you have any play at the road wheel when the wheel is off the ground (vehicle jacked. take care)
Old Jun 30, 2006 | 02:53 PM
juanpablo's Avatar
no play on the road and when its off the graund things feel good and look good
Old Jul 1, 2006 | 04:34 AM
snanceki's Avatar
OK,
I repeat. Find out what is wrong straight away! It may be something very important.
"disk rectifi with new breaks" Does this mean you have had new rotors, not just pads? Why did you do this. To try to repair the vibration or before the problem started?
Where did the rotors come from. MB? The amount of thick/thin and runout on the disk is very important. If the problem started after they were change i will explain further.
Are the wheels original eqipment? If not do they register correctly with the hub? Have the wheels been refitted correctly? Were the bolts torqued in the correct sequence and to the correct setting? The wheels can distort the disks if incorrectly fitted.
What condition are your tyres in? Has one been kerbed?
Since the car is 2004 what does the dealer say? You shouldn't have a problem like this.
Old Jul 3, 2006 | 02:58 PM
juanpablo's Avatar
thanks i am working on that
i will post you what was wrong ....
thanks ...!!!
ml320 in OZ
Aug 3, 2009 09:20 AM
dhmaher
Feb 17, 2007 01:51 AM
My wifes C
Aug 1, 2006 12:47 PM
xriss55
Apr 5, 2004 02:52 PM
