horn stopped working
I adjusted my steering wheel and it appears that something is wrong because the horn won't sound now. It may have been from something else (you don't blow your horn every day) but I checked the fuse and it's good.
Does anyone have any other ideas?
I checked the fuses, the K40 relay and pretty much everything else I could think of. Is there a connection in the steering column that could come loose. Is there a way to open the housing around the steering wheel?
I pulled the dash and found the "ribbon cable". there doesn't seem to be any issue with it. I pulled the grille and both horns are connected. I don't know where else to go. Does anyone have a diy on how to get to the buttons in the steering wheel. Do i need to disconnect the battery to prevent the air bag from going off.
This is almost embarrasing. It was both horns. Who would think that both horns would go at the same time. A quick trip to Autozone and $38.00 later ... HONK!
Sorry but at least this may be a lesson to check the obvious sometimes.
patricknif
Mar 4, 2012 06:38 AM
avcomm22
Mar 14, 2008 08:13 PM
