FOGGED UP WINDOWS
Old Mar 27, 2008 | 11:39 AM
tancalvo's Avatar
Default FOGGED UP WINDOWS
HEY I LIVE HERE IN RAINNY VANCOUVER BC AND I HAVE JUST NOTICED LATELY WITH THE WEATHER THAT WHEN I PARK THE CAR AT WORK IN THE MORNING THE WINDOWS GET FOGGED UP...I PARK THE CAR UNDER GROUND WITH (THE WINDOWS CLOSED). DURING THE NIGHT AND I HAVE CHECKED ALL THE MATS ARE DRY....NO WATER I HAVE EVEN RAN THE AC WITH THE CIRCULATE BUTTON ON SO NO OUTSIDE AIR GETS IN ...ANY IDEAS ...HAS ANYONE ELSE HAVE THIS..
Old Mar 27, 2008 | 12:23 PM
052453a's Avatar
Default RE: FOGGED UP WINDOWS
Leave the roof down....just kidding. Although, maybe you should try lowering one window a bit to "normalize" the inside/outside temps. Sounds like a dew point issue.
Old Mar 27, 2008 | 08:09 PM
DoubleNickle's Avatar
sounds like you need to get rid of the horny girl in your back seat
Old Mar 27, 2008 | 08:11 PM
ha ha never mind i just saw that you have a slk....no back seat sorry
Old Mar 28, 2008 | 01:14 PM
tancalvo's Avatar
ALL GOOD SUGGESTIONS BUT I STILL SEEM TO HAVE FOGGED WINDOWS..MY WIFE FOUND OUT ABOUT THE GIRL THOUGH HAVE NO PROBLEM WITH THE WINDOWS BECAUSE THE LAWYERS WOULD TAKE IT...
Old Mar 30, 2008 | 12:05 PM
snanceki's Avatar
Usual cause of fogging windows (apart from the suggestions already put forward) is when the A/C evaporator drain is blocked.
You don't ident vehicle type...someone suggested SLK?...
S Class are extremely prone to the A/C plenum (air inlet) drain being blocked but it is usually the evaporator chamber drain.
Does the fog clear with the A/C running? with and without recirc selected?
Stuart
Old Apr 24, 2008 | 10:18 PM
RicksAlias's Avatar
I have a 2003 SLK-230
Whenever I start it up, the AC blows a HOT, incredibly HUMID blast for about 4 minutes.
It's so humid, it fogs up all the windows until the AC cools down and starts to defrost things.
(Oh, I'm in San Diego and it's "summer")
I suspect that the evaporator drain is clogged.
How can I get to it?
Does anyone know where I can access it?
From the inside? From the outside?
Rick
milliontogo
Aug 31, 2005 11:49 PM
cab713
Aug 16, 2005 12:20 PM
engenuity
Mar 12, 2004 03:21 AM
jmnorton
Nov 25, 2003 11:53 PM
