420 SEL Headlight problem - help?
Old Sep 11, 2005 | 02:32 PM
jsosb1969's Avatar
Default 420 SEL Headlight problem - help?
I've had my 1989 420 SEL for about 2-months; I couldn't be happier. However, last night when I was driving home - I hit the "high" beams and the headlights went OUT. I can't get them to come back on. In fact, the "high" beams don't even work in the switched-on position - but they do work when I hold the switch down. Any thoughts? The fuses look OK (none busted) but a little corroded. The problem with the fuses is - I can't figure out which one(s) control the lights; it's in French (of all things - how odd is that)?
Any help would be greatly appreciated.
Jason
Old Sep 12, 2005 | 02:37 AM
jsosb1969's Avatar
Default RE: 420 SEL Headlight problem - help?
Well - for anyone out there who is having the same problem -I think I've figured it out. [sm=happybounce.gif]
The switch on the steering wheel column appears to be the issue. A little big of wiggling, pushing (and swearing) [&:]seems to have gotten the headlamps to come back on. The only problem is - they go out again if you hit the switch to turn on the high-beams (yes, I was dumb enough to try it again instead of thanking my lucky stars that the lights came back on lol).[sm=badidea.gif]
Does anyone know how to replace that switch or where to best place to get one is?
j
Old Sep 13, 2005 | 07:53 AM
bazzle's Avatar
What sort of Benz is a 420 SEL??
Bazzle
Old Sep 13, 2005 | 10:24 PM
jsosb1969's Avatar
1989 420SEL??? It's sort of a land yacht. It's a big 'ol Mercedes - 4 door - loaded to the teeth.
Old Sep 14, 2005 | 12:16 AM
sleepwalker's Avatar
420SEL older S-Class
body: 126.035
produced: 1986-1991
it's the younger sister of 560SEL with funny looking engine.
Old Sep 15, 2005 | 07:37 AM
bazzle's Avatar
I see.
Try the S class forum , they may have your answer there.
https://mercedesforum.com/forumid_9/tt.htm
Cheers BAzzle
gonzaga707
Dec 7, 2010 11:42 PM
northbeachfilms
Jul 28, 2009 02:24 PM
auburn_tiger
Nov 7, 2007 01:44 PM
jcirilo
Aug 12, 2007 10:20 PM
bsutton101
Oct 6, 2004 05:47 PM
