Window problem--SL55
Old Mar 22, 2010 | 09:48 PM
ctjstr's Avatar
Default Window problem--SL55
This CANT be that difficult, but its enough to have me stumped.
Recently had my batteries disconnected. Now everything is back together, but I've got a small problem. When you open the door, the window opens a crack so that when you shut it, the air pressure is reduced. then the window rolls itself up the last little bit.
But now, after re-connecting the battery, when I shut the door, the window does not roll up.
I'm guessing I've either screwed up some sequence or something, but its got me wondering.
Any suggestions?
thanks in advance.
Old Mar 26, 2010 | 11:01 PM
bearsbusa's Avatar
Press the window switch in the up position and hold for 5-6 seconds after the window has closed. This will re sinc the windows.
Old Mar 28, 2010 | 08:43 AM
ctjstr's Avatar
thanks. Tried it and it worked perfect. Appreciate the response.
Old Apr 11, 2010 | 07:11 AM
rgrayoh's Avatar
I have a 94 SL500. It seems that when I am rolling up the windows they go up really slow. Like something is sticking but there is now. My son has sprayed lubricant on the window track where his windows go up and down on his old cars. Should I do this or can anyone tell me the problem I am having and how I can fix it?
Old Apr 12, 2010 | 09:23 AM
ctjstr's Avatar
Roger
I can't speak specifically to mercedes on this issue, but from my experience on lots of other cars, the lubricant thing can work somewhat, but in general, if that window is rolling up slower, you're eventually looking at a motor. I've replaced them on several cars and they're not that difficult. Judging by how many aftermarket window motors I see for sale for mercedes, I'd guess this is not that unusual of a problem.
good luck
ifthecar
May 12, 2013 02:07 PM
Faramir
Aug 30, 2012 08:24 AM
55cs
Apr 20, 2012 07:10 AM
lakv8
Jan 6, 2011 05:25 PM
Rockerfella174
Apr 20, 2008 09:52 PM
