soft top wont go up
Old Aug 26, 2007 | 10:34 AM
hpy's Avatar
hpy
Default soft top wont go up
I got the hard top off no issues but the soft top doesnt go up I here some noise in the behind me
I'm new to this and the car has no manual (I guess that will be a first item any thoughts on a good manual)
I like to leave the hard top off Is there any manual process ?? or any instructions I can get tohelp a newbe
hpy
Old Aug 26, 2007 | 11:07 AM
SunGuy62's Avatar
Default RE: soft top wont go up
Welcome Newbie-
You can go to this site below and download an owners manual for your car.
http://www.benzworld.org/forums/r129...load-site.html
If you have the toolkit that originally came with the car, you can manually put the soft top up using the 'special tool' that is in the toolkit. Specifics are in the owners manual.
If, as you state, the hardtop released (front latches, etc) then you may have a problem rooted in the soft top controller. Best bet is to read up on how this bad boy works and what you can do to test/re-set. Use this link...
http://www.benzworld.org/forums/r129...ontroller.html
The moderator, LynnS, at the site I'm referring you to has aggregated an enormous amount of info onour sometimes problematic tops. You can also use the 'Search' function at this forum as well to read up on solving your specific issues.
Good luck with this, and after trying a couple of the remedies suggested, please post how you make out and specifically what happens when you activate your top system. BTW, since this is a signifigant drain on the battery, have the motor running when you activate the top system and/or re-synch the windows.
Bob
Old Aug 26, 2007 | 12:19 PM
hpy's Avatar
hpy
Thanks for the info Bob
I'm reading the manual now
its raining here so I will try your suggestions tomorrow
hpy
tomybooy
Nov 25, 2016 10:51 AM
Max Macson
Apr 20, 2011 09:18 AM
Terry
Nov 4, 2007 07:15 PM
SFRoadster
Sep 3, 2007 09:11 AM
V XII
Jun 9, 2006 09:24 PM
