SL 320 1995
Old Oct 30, 2004 | 09:53 PM
DJ's Avatar
DJ
Default SL 320 1995
Hello there everyone.. I,ve just joined and find the site very interesting. I have a 1995 sl320 with a couple of problems. I recently put new shocks and springs all around but the front is a lot higher than it should be. I used all origional parts and the dealership say that new springs for this modle do this. I,m tempted to replace all with an AMG suspension as the front rides very giddy. Also the heaters will only give very cold or very hot air and cannot be adjusted for some reason. The central locking always locks ok but could take a few attempts to open even though the green lights flash nothing seems to happen, also i have to be very close to the car for the remote to work even after changing the bateries. I'm from Ireland and a specialist seems to be very hard to find.
Any comments would be greatly appreciated.
DJ..
Old Oct 30, 2004 | 10:36 PM
sleepwalker's Avatar
Default RE: SL 320 1995
you can lower the front height a bit by changing the rubber spacer on the spring.
the blender flap element on the airconditiong is not functioning.
there is a leak on the PSE pump on pressure side. (vacuum - lock, pressure - open).
poor signal from infrared receiver.
qghauri
Jul 7, 2006 05:20 PM
qghauri
Jan 21, 2006 03:19 PM
qghauri
Jan 15, 2006 05:57 PM
qghauri
Jan 9, 2006 03:51 PM
qghauri
Jan 5, 2006 06:15 PM
