please i need help real bad
Old Feb 27, 2010 | 05:04 PM
mercedes_lover's Avatar
Default please i need help real bad
to all of expert. i am new to this forum. i just got the sl 500 2005.
some how the license plate light bulb 1 of them is burned out. i got the part already, but i could not change it, actually i dont know how. please help me, i asked the shop and it costs me almost 200 to do it. i am so dumb
thanks for your help in advance.
Old Feb 28, 2010 | 02:35 AM
sleepy_b's Avatar
Should just be 2 phillips screws holding the cover on and then pull the bulb out and put the new one in. Unless you are changing the unit. Some can be changed by poping it out from the outside and others you have to go in through the inside of the trunk lid. Shouldn't be to hard to just a bulb. I can't beliave they want 200 dollars to change it.
Old Feb 28, 2010 | 09:39 AM
ab4jy's Avatar
Default Bulb
Ditto to last response....2 phillips screws
Old Feb 28, 2010 | 09:47 AM
mbz connexion's Avatar
If it has the 2 screws and still feels tight once they are removed you may need to use a hook and give it a little tug from the corner.
Old Feb 28, 2010 | 03:00 PM
to all experts. i was trying the way you have been show me already but some how there is another like mirror cover the bulb. should i try to pull them out too or i have to open from inside the trunk.
please help me to the end.
thanks alot
bahalll
Nov 23, 2009 02:36 PM
MARIODRIVE
Nov 23, 2008 05:39 PM
1bads500
Apr 9, 2008 12:44 PM
jkroeis
May 5, 2006 10:20 AM
