Oil Change
to save labor costs, it's not any different than any other car as far as draining the oil. you'll need to remove the cover under the car to access the drain plug using a 8mm socket, a 13mm wrench for the plug and a 3/8" ratchet with an extension for a mercedes/German oil filter socket wrench to remove the filter canister cap that is located on top of the engine.
I never had more than 5K in a year, and always changed annually, so was a moot point for me.
Thanks for the info.
floresadolfo1
Jan 26, 2007 04:15 PM
