OBDII link issue
not sure if you have a fuse chart but if you do check the fuses for OBD2 or diagnostics. ive worked on cars in the past that the fuse was pulled for the diagnostics...possibly in hopes of getting past emmision test. check the obd2 connector under the dash. remove the panel and look at the connections. hard to say what it could be.
Joe B.
Jus2laziee
Mar 29, 2018 04:37 PM
