Location of windshield wiper relay
Old Aug 6, 2019 | 07:38 PM
svchama's Avatar
Default Location of windshield wiper relay
Can anyone tell me where the windshield wiper relay is located on my 1994 SL500? The wiper has stopped working in the intermittent and low positions. The wiper only works in the high position. Thanks
Old Aug 8, 2019 | 12:46 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Take a look at the link below to one of our site's DIY tech articles. Hope this helps you out a bit.
https://www.pelicanparts.com/techart...eplacement.htm
Old Aug 9, 2019 | 12:48 PM
brookings's Avatar
those relays are usually very dependable but is the second largest relay in the fuse and relay box at the back of engine compartment drivers side.
Old Aug 19, 2019 | 09:34 PM
svchama's Avatar
Found it. Thanks. You say that these relays are usually very dependable. Can you think of another reason that the wipers would only work in the high position?
Old Aug 21, 2019 | 05:32 PM
brookings's Avatar
if not a poor connection, issues can come from the multi-switch not to say the relay can't be bad.
Old Oct 9, 2025 | 03:28 PM
vapofi's Avatar
Can anyone tell me where the windshield wiper relay is located on my 1994 SL500? The wiper has stopped working in the intermittent and low positions. I’m also considering a windshield reseal while addressing this issue. The wiper only works in the high position. Thanks.
On a 1994 SL500, the windshield wiper relay is built into the wiper switch module on the steering column. Since high speed still works, the intermittent/low circuit or the switch itself is likely faulty. Replacing the wiper switch module usually resolves this issue.
fretless5
Mar 8, 2013 06:49 PM
gwbrehm
Oct 23, 2008 02:54 PM
s_gilbride
Apr 25, 2006 05:46 PM
evillwock
Dec 6, 2005 12:50 PM
Norseman
Jan 4, 2005 08:26 AM
