im buyin an SL needed some info
Old Dec 14, 2008 | 04:51 PM
gzelda8's Avatar
Default im buyin an SL needed some info
hey guys, i plan on buying a SL500, year 2003 to 2006. wanted to know which year you would recommand and which to stay away from. goods and the bads, and any other recommandation that you have. thanks for the info.
Old Dec 14, 2008 | 07:47 PM
BeltFedBob's Avatar
Default RE: im buyin an SL needed some info
What ever you get...get warranty.
I have a 05 SL55AMG and it has had a SC clutch replaced, both door IR sensors, air conditioning line leak and drier replacement, both front motor mounts, voltage regulator, and rear batteryfailure. On it's third set of brake pads, second set of rotorsand second set of tires. All dealer serviced.
Now it looks like the throttle pedel position sensor is failing, sets code and goes into limp mode.
It just turned 26,000 miles.
Good luck!
Old Dec 14, 2008 | 10:25 PM
brookings's Avatar
go to www.cars.com go to used mercedes sl, find any yr you want to check, click on, then go to research and then quality ratings. these are J.D. Power ratings.
skidds327
Mar 13, 2012 04:34 PM
ryanbigcheese
Oct 31, 2009 03:20 PM
LS1 Owner
Mar 15, 2007 12:46 PM
loveallnightlong
Feb 11, 2006 06:35 PM
paerikss
Feb 25, 2004 07:14 PM
