fyi working on anything electric on your 230sl
Old Nov 4, 2019 | 09:17 PM
brookings's Avatar
Default fyi working on anything electric on your 230sl
make sure you disconnect the battery ground or suffer the consequences. not everything requires a disconnect, but if not sure pull the ground. I messed up my srs after removing seat and my hand held diagnostic scanner won't reset error message. need sds
Old Jan 15, 2020 | 04:42 PM
brookings's Avatar
do not position the seat by the headrest when reinstalling. that will open another can of worms.
Old Apr 5, 2020 | 12:25 AM
brookings's Avatar
the whole reason for removing seat to fix the lumbar, etc adjustment was to assume a vacuum pump purchased a year or so earlier was impossible to be bad already. well as it turned out the new pump was bad. I checked at the seat vacuum reservoir behind the spare tire for vacuum, there was none. wish I would have checked there first. would have saved a lot of time in looking for a problem elsewhere in the system. two pumps in 45,000 miles, I went with a rebuild for this replacement. $350 is better than 800. think this could be another weak spot.
stang0303
Dec 21, 2021 08:49 AM
Karim Tawil
May 1, 2017 03:57 PM
IanW
Sep 19, 2008 09:05 PM
harvinder25
Feb 6, 2008 12:25 PM
truespin201
Jun 9, 2004 07:27 PM
