Engine Cuts out at 5000 RPM
94 6.0L V12 Engine is cutting out at 4000-6000 RPM
Told I need to replace the Fuel Injection Rack - quoted $7000
Does this sound correct?
Is there a work a round to repleacing the entire injection rack?
If I want to replace the entire engine, can I dump the 12 for a L6 without fabricating tranmsisson and motor mounts?
is it in gear when it is cutting out or park. also i have never seen anybody replace a fuel rail on a v12 motor. if it is cutting out when you rev it to 5000 rpms when it is in park then this is normal.
ORIGINAL: V XII
You could save quite a bit of money doing the work yourself. This guy has detailed instructions on repairing the wiring to the throttle actuators so that you don't have to buy new ones: http://v12uberalles.com/throttle_actuator_rewire.htm.
It would be very expensive to substitute a 6-cylinder engine. You'd need to buy new wiring harnesses and control modules.
76benz
Aug 31, 2005 12:06 PM
