Creaking noises on 2001 SL500 ?????
I have a 2001 SL500 bought about a year ago. It has only 34K on the clock. The car makes creaking noises when I turn the wheel about 1/2 turn while standing still or moving slowly...as in backing out of the garage.
Anybody ever heard of this??? Any response will be welcomed.
I too had creaking noises, and thought it was steering,suspension etc. After typing "creaking mercedes" into google, I found that it is a common problem. It is a rubber bush (hopefully) behind one of your front wheels, look for it or feel for it, and give it a spray with WD40. This sorted mine out immediately,the noise is just dry rubber. You may notice that it never creaks on a wet day.
ORIGINAL: BOSTON JOE
Take alook at this post and see if it helps. It's a real cheap fix if it solves your problem.
http://www.benzworld.org/forums/r129...ght=hood+latch
Use A silicone based spray with a needle and spray into that lower rubber bushing and it will stop it. I had the dealer tell me to do just that. I used a Lithium grease spray also. It fixed it all the way.
notShai
05-11-2010 12:40 PM
