ABC-Hydraulic oil
Old Sep 4, 2021 | 02:12 PM
Ragnvald's Avatar
Default ABC-Hydraulic oil
I have a SL500, R230, 2003 mod. I`m trying to find a replacement oil for the MB hydraulic fluid in the ABC system. I know that some are using Pentosin CHF-11S for this service. However, as far as I can see based on MBZ approval 345.0, the Pentosin CHF-11S is only MBZ approved as hydraulic oil for the power steering in relation to the R230. Will appreciate any comment regarding use of the Pentosin CHF-11S versus the MBZ`s supplied ABC hydraulic fluid.
Old Sep 4, 2021 | 03:20 PM
brookings's Avatar
use the pentosin for the abc. use 20 to 25k miles.
Old Sep 13, 2021 | 05:40 AM
Ragnvald's Avatar
Thanks for the reply. I have left a quart of the MB oil. Do you know if it will be ok to mix this with the Pentosin?
Old Sep 14, 2021 | 03:28 PM
brookings's Avatar
is it blueish in color? it may be the same but usually more expensive. when in doubt, don't
Old Sep 15, 2021 | 04:46 AM
Ragnvald's Avatar
The color is green, same as for the Petosin. I see that MB have different part no. for the power steering oil (Petosin CHf 11S) and the ABC oil, i.e. A0019892403 and A001989240309 respectively. I have not been able to establish the specification for the latter so the possible difference is unknown. Your "when in doubt, don`t" seems like a reasonable solution. Thanks.
Old Sep 15, 2021 | 04:47 AM
Ragnvald's Avatar
ajm
Apr 8, 2009 04:48 PM
RRWatch
Mar 26, 2009 01:12 PM
starwoodvo
Feb 14, 2008 06:09 PM
ianvandy
Aug 13, 2007 05:25 PM
RockSolid
Jun 24, 2006 06:41 PM
