93 300sl
It's either the instrument cluster or the ESCM module that sends the tach signal to the cluster. You can check that signal by measuring it's frequency at different engine speeds and comparing to reference values. If you are able to do that and want help, post back.
If you remove the cluster you'll find 2 round connectors and 2 others. The tach signal is on socket #13 of the round connector that looks like the picture. At an engine speed of 1000 RPM you should measure roughly 50 HZ, and at a speed of 4000 RPM 194 HZ.
azdesertDog
08-24-2004 11:30 PM
