450SL Front Brake Pads Wont Clear Width of Rotors
Old Oct 4, 2008 | 06:20 PM
greenl's Avatar
Default 450SL Front Brake Pads Wont Clear Width of Rotors
Hi. I have a 1979 450SL and I recently bought new brake pads. The backs werent a problem to install, but I cant get the fronts in. I can't seem to expand the pistons far enough into the calipers to clear the width of the rotor with the new brake pads. The pistons "look" like their far enough in, but the pads still wont clear the rotor. Any suggestions? Thanks.
Old Mar 15, 2012 | 11:34 AM
rayfry's Avatar
loosen the master cylinder cap to release pressure and the calipers should compress. Put a rag under master cylinder incase any brake fluid drips.
Old Mar 15, 2012 | 05:19 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
I'm certain that you already overflowed the master cylinder if you didn't remove fluid befor starting the job. I use a new turkey baster. I'm also certain this job has been completed but I will reply anyway. I always found if I put the old pad against the caliper piston and then use a C or bar clamp, I can squeeze the piston back flush to the caliper, then they will fit around the rotor with the pads on. This is also a good opportunity to bleed out old brake fluid while topping off with fresh Dot 4.
PelicanParts.com
Jul 8, 2013 11:08 AM
juanao
Jun 12, 2008 02:52 PM
seitz729
Nov 28, 2006 03:40 AM
cgmacneil
Nov 24, 2006 06:51 PM
eurocarsnut
Nov 20, 2003 04:32 PM
