380 SL 1985
I just told a friend that I would put a fuel pump and an antenna on his
85 380 sL. It looks stright forward. What should I know ? I work on my own 62 Corvette. I saw were some one asked about bleeding the pressuer off? Do I need to do that ? How ? Do I have to prime the new one??? Thanks for any help. He had been told this would be around $700.
I found the parts on e-bay for less than $200. I will not charge him for laybor.
I replaced the pump tonight . But I can't get it to stop leaking. I reused the two metal washers. The new one had no washers.. Can I buy new ones? What do I ask for? Can i use a sealer?? What kind???? Thanks!!!!!!
It's best to find new washers for the banjo fitting but if the old ones are not too compressed you can reuse them. Lay a piece of fine sand paper, something like 400 grit, on a flat surface and rub the washer on it lightly with your finger. It's soft and you don't need to take off much-- you are just trying to take off the ridges and get smooth, flat, parallel surfaces.
