1992 SL550 Service bulletin
Old Jul 10, 2012 | 12:53 PM
mabbas's Avatar
Post 1992 SL550 Service bulletin
I,m looking for service bulletin issued March 1996 # 68 005A.
I'm trying to remove the center panel to access/change window switches.
Thanks.
Old Jul 11, 2012 | 12:53 AM
brookings's Avatar
if you have an oem stereo head unit there are a couple of slots on each side at the bottom of the unit. you'll need to purchase a couple of key like head unit removal tools off ebay or from your dealer to remove the head unit. once the head unit is out reach through and push out the climate control module from behind. lift open the small storage door just ahead of the shifter and remove the one screw in the middle front of the compartment. then pull both of the felt sides of the storage compartment toward the inside of the compartment. they are hinged and pull at the top of the sides. remove felt compartment. remove the two screws under the compartment. remove trim around shifter. then push down at the back of the console wood trim, behind the shifter toward rear of the car, and push it to the left and then push down on the right side and push the trim to the right. there are a couple of catches underneath.
Dave3359
Apr 23, 2015 04:57 PM
rlw
Jul 8, 2007 01:09 PM
DaltonTheCooler
Nov 7, 2006 08:44 PM
konman
Sep 23, 2006 02:19 PM
3no
Sep 20, 2006 05:39 PM
