1973 450SL M117.982 Engine Rod Bearings Loose
Old Dec 14, 2007 | 06:49 PM
lmarty1359's Avatar
Default 1973 450SL M117.982 Engine Rod Bearings Loose
Help!! I've replaced the rings, crank bearings and rod bearings. The rod bearings have a slight play when I've torqued them to 45 nm (33 ft/lbs) and 90 degress for angle of rotation (all by the book). Surely there should be no play in the rod bearings. Will this happen if the rod bearing bolts are already stretched too far?
Thanks so much!!
[IMG]local://upfiles/27769/87C74AE3F3A84072A90750C0586EA69B.jpg[/IMG]
Old Dec 15, 2007 | 11:51 PM
vytamenc's Avatar
Default RE: 1973 450SL M117.982 Engine Rod Bearings Loose
this my be a stupid question but where did you get your berrings? please tell me the dealer. there is so many different berrings for these car its unbelievable there are different berring pending what size rods you have and what size caps you have and cannot be mismatches there is a leter code on the counter weight on you crank that telles you what set of berring you need for each rod.
Gumpyman
Dec 19, 2022 10:49 AM
bostonmish
Dec 3, 2009 11:39 PM
raffo
Jul 5, 2009 01:58 PM
lmarty1359
Nov 3, 2007 09:07 PM
Placey
Feb 17, 2006 06:27 PM
