Xenon Problems
Old Dec 31, 2009 | 09:07 AM
mbamiami02's Avatar
Default Xenon Problems
I have a 2002 S430. The driver's side Xenon headlight turns off whenever the engine is running. Turn the engine off and the headlight immediately turns back on. No problems at all with the passenger side headlight. I've called about 10 different dealers and have gotten all sorts of answers-bad bulb, bad control unit, bad wiring, bad alternator, bad headlamp assembly, etc. Any advice?
Old Jan 18, 2010 | 09:20 PM
Rockerfella174's Avatar
hi mbamiami02,
ive come across to this problem before, i ve replace the wire & the bad control unit.. send your car to a proper mb garage / workshop for replacing it because the unit is quite expensive.
good luck!!
rockerfella174
Brunei darussalam
Old Jan 19, 2010 | 04:16 AM
mbamiami02's Avatar
Thanks for the reply. Is the control unit the same thing as a ballast? Is it manufactured by Bosch? Hella? I know that they're quite pricey so I'm considering buying a used one online. I figure I could save about $750. Thanks!
Old Jan 20, 2010 | 07:24 AM
hi again,
yup,you got that right..! replace em..
rockerfella174
Old Feb 6, 2010 | 03:06 PM
mikkylewis's Avatar
Where is the Ballast located in the S55 2002 and what is the fastest way to replace it
Old Feb 9, 2010 | 08:30 PM
Mambo's Avatar
When your Xenon works normal when you turn off the engine you can conclude that the whole Xenon system works fine. There is nothing wrong with your 'igniters' (or ballast) and the lights.
The problem lies somewhere in your relais and that should not be an expensive affair.
Normally you have a wire running directly from the battery to the lights and another one to the relais. If the Xenon works you can rule out that complete section.
Don't go replacing Xenon when it is not necessary.
At least that would be my idea.
Get into the electrical diagrams and find out how the unit is switched, the problem could be much simpler that you think it is.
________
California dispensaries
Old Oct 8, 2010 | 04:15 PM
bruce03's Avatar
Try to change your xenon with lower intensity discharge may be heavy intensity discharge cause this problems
amgalex
Aug 11, 2009 11:25 PM
toien
Jul 23, 2007 01:04 PM
TheV12pwr
Dec 12, 2004 01:15 AM
lulu
Jun 18, 2004 12:09 PM
GT56E4
May 10, 2004 03:07 PM
