Upshift Delay - Code 26
Old Sep 7, 2008 | 02:13 PM
Wisegy123's Avatar
Default Upshift Delay - Code 26
The check engine light came on in my 1995 S420. The technician pulled Code 26 from his diagnostics. He said that this is Upshift Delay. What exactly is upshift delay, what causes it, and how is the problem fixed ? Any help that is offered will be greatly appreciated.
Old Sep 7, 2008 | 02:22 PM
chassis221's Avatar
Default RE: Upshift Delay - Code 26
a valve that is on the right side of the transmission above the trans oil pan. it has vacuum hoses going to it and a cable that goes to the throttle linkage. controls the trans upshift delay, to heat the cats in the morning.
Old Sep 9, 2008 | 09:06 PM
Wisegy123's Avatar
What exactly has to be done to fix the problem ? Is it harmful to drive the car with this condition existing ?
Old Sep 10, 2008 | 05:24 PM
chassis221's Avatar
the upshift delay needs to be replaced...or there is a vacuum line off of it. its located on the right side of the transmission above the oil pan and is right up against the tunnel and is tough to get to... usually you have to remove the trans pan to attach the cable and you need to adjust the shift points with the screw on the back side of the upshift delay ....just compare the distance the scew is backed out from the old one to the new one.
gwint123
Jan 30, 2011 09:04 AM
Broken Yolk
May 18, 2010 11:46 PM
aymank1983
Mar 20, 2010 06:01 PM
amg5872
Oct 7, 2007 02:04 PM
rsmartin
Jul 28, 2006 03:51 AM
