Steering Shock
Check the shock; cheap to replace, and you gotta have it working. Tires must be balanced and good; 126 chassis is kinda sensitive to bad tires on the front. Be sure to check the steering idler while you're under there.
Regards,
randy
Regards,
randy
Thanks fellows, I am going to order a steering shock, get the tires balanced and the alignment checked. According to your responses, this should take care of the problem.
