S600 power steering pump question
Old Dec 13, 2006 | 06:47 PM
bergfurher's Avatar
Default S600 power steering pump question
I have a 1994 S600 coupe, recently, the steering pump started making noise when the wheel is turned, but seems to go away after about 15 minutes of normal driving, the fluid level was low, I topped it off with the correct fluid, but the noise is still there, it sounds like the pump is running with no fluid it it, but has fluid, the rack turns fine, no problems, not tight, the system works fine, but the pump is very loud, any ideas?
Old Dec 13, 2006 | 08:59 PM
sleepwalker's Avatar
Default RE: S600 power steering pump question
air bubbles?
Old Nov 19, 2008 | 10:55 AM
august240's Avatar
Default power steering level ML320
Sleepwalker hi, how do I measure the power steering fluid level of a ML320 2001 model...?there is a min. 20oC max. and min. 80oC max.... Thanks, kababayan...
Old Nov 30, 2008 | 09:10 PM
C280 SPORT's Avatar
Default RE: power steering level ML320
I have the same thing in my 2000 C280. It only makes the noise when turing it to the left and only when it is cold out.
keilind3
Sep 9, 2009 09:35 PM
os101king
Jul 26, 2007 07:47 PM
kanio
Sep 15, 2006 04:25 PM
Benz450SLC
Oct 11, 2005 11:47 PM
1monstergarage
Apr 14, 2005 02:24 PM
