S420 Oil Pressure
S420 Oil Pressure
Oil pressure occasionally stays at 3 bar during hot idle. At other times it's at 3 bar at +1500RPM and drops to 1.5 bar at hot idle. All maintenance points hit. Car has 137,000 miles, but still runs and drives perfect. No noises from engine either hot or at start up. Engine temperature normal. Any recommendations? or is this expected.
RE: S420 Oil Pressure
140s idle at almost nothing, but they have a two stage pump and somewhere over 1000/1500 the needle should peg or be near the top. It does depend on the oil viscosity, typeand the ambiant temperature. A cold engine would yield higher pressure at starup
