s320 vacum system
Old Nov 10, 2006 | 11:02 AM
jaalmodo's Avatar
Default s320 vacum system
I hae a 1999 s320, think i have problem with vacum system. The trunk closing latch mechanisim retracts than it comes out again. Also notice that the lumbar suports on both seats start pumping air by themselves. I think the system leaks than it refills. Anyone had any problems like this.
thanks.
Old Nov 11, 2006 | 03:49 AM
vytamenc's Avatar
Default RE: s320 vacum system
yup i have seen it quite a few times you need to check your system for leaks. with a vacuum / pressure guage
Old Nov 11, 2006 | 10:43 AM
Peter Guenther's Avatar
The locking pump under the pass rear seat handles the lumbars (it pressurizes a reservoir) and replenish it. The pump drives the handle , the locks, the manual headrest, and auxilliary vacuum for the HVAV. It has timing cicuits and safeties.
Pressure to lock, vacuum to unlock, The handle should retract, it appears the pump suts off prematurely before the handle is in. The best tool is called a MIghty -Vac lets you draw a vacuum and and look at the guage to see if it leaks down. Plastic $30/aluminum$50
weagwan
Sep 23, 2009 07:18 AM
seagreen12
Mar 2, 2007 09:01 PM
bobnpat
Jul 30, 2006 03:51 PM
Benz_190
Feb 25, 2006 01:44 AM
Bill Melater
Jun 23, 2005 01:49 AM
