S320 Limo - replacing window motor
Hi all,
A new memebr to the forum. I have owned a S320 Limo (1999 old shape) for the past 2 years and enjoy it very much.
A couple of months ago, my driver side window stopped going up and down, and i have had to push the double glazed glass up by hand. Every now and then it slides back down due to the shear weight of it. I have enquired on getting it fixed and the cost quoted have been £400 labour + parts. Iam told I have to replace the motor!
I have purchased a motor from a breakers,and would like to replace it myself.
Hence why I am here asking anyone if they have had to replace it? I can not find any screws/fixing caps etc onthe door panel and can not see how the panel may be removed??
I have spent quite alot of money on parts and labour over the 2 years, and can not afford to pay someone else to do anything, I could perhaps do myself!!
I would really appreciate anyone's help on this.
Thank you in advance.
there are 2 screws in the door armrest, under the hinges of the armrest/ pocket. then you must remove the wood trim by your grab handle in the door, its a sort of triangle shape wood trim( careful not to break the trim its $$$) and there is a special tool to take it out. then there is a screw under thegrabhandle, door panel will have door clips around the perimeter of the door panel unpop them them slide panel up and out.
Thanks for the advice.
I was beginning to think no one could help.
As it happens, I braved it over the weekend and tried to remove the panel myself, which wasn't too difficult. The most difficult part was to remove the mechanism which carries the window.
islandercreation
Dec 16, 2007 02:21 PM
