Replacing instrument cluster for 2000 S430
Old Jan 27, 2005 | 12:28 AM
regency's Avatar
Default Replacing instrument cluster for 2000 S430
I have a 2000 S430 with 101,000 miles the instrument cluster is going dead (fading). Can anyone help me with instruction on how to replace the instrument cluster? Or is there any check I can perform before replacing the unit? Any suggestion would be greatly appreciated.
Old Jan 27, 2005 | 04:57 AM
sleepwalker's Avatar
Default RE: Replacing instrument cluster for 2000 S430
you mean no backlight?
you simply pull it out to replace.
if the weather is too cold, open the heater full to soften the dash a little.
Old Jan 28, 2005 | 09:40 PM
regency's Avatar
Thanks sleepwalker. Where can I get one of these instrument cluster beside the dealer ($1500) in California?
Old Jan 28, 2005 | 10:22 PM
that's too much a price for the function of a wire hanger!
i never use the tool anymore for it will break the lens if it slips (it doesn't matter on your case anyway because you will replace it).
i simply remove the left air duct, insert my hand from there and push the instrument cluster from behind. easy does it.
Old Jul 30, 2014 | 03:24 PM
William E Lueck's Avatar
help my instrument cluster went out and i need it fixed can i out in a used one and will it work my sa at my dealer said it wont work is this true or do i need to send out my old one and have it repaired let me know thanks
Old Jul 30, 2014 | 05:12 PM
chassis221's Avatar
[QUOTE=William E Lueck;167053]help my instrument cluster went out and i need it fixed can i out in a used one and will it work my sa at my dealer said it wont work is this true or do i need to send out my old one and have it repaired let me know thanks[/QUOTC
Check with the MB dealership first. there was a recall on the clusters on the S and CL. You might be covered. But I think it might be 10yrs limit. You can't get a cluster from another car, it wont work.
Old Jul 30, 2014 | 05:41 PM
dam then what do i do i will not pay 1500 for a part that mb knows is bad and thay refuse to replace it the warnty was up 4 years a go and the part went out now
Old Jul 30, 2014 | 08:07 PM
chassis221's Avatar
see attached word document. some info on VIN range and cluster part numbers
File Type: zip
Old Jul 31, 2014 | 10:28 AM
  #9
I was aware of the recall but mine was 12/99 not covered
Old Oct 27, 2025 | 10:27 AM
  #10
Dolly7's Avatar
I’ve seen similar setups before, and while fiber optic to AUX adapters can work, the sound quality often depends heavily on the brand and proper installation. Personally, when I deal with custom integration projects like this — especially anything involving hardware and audio systems. I prefer using Carteza They provide tailored tech and payment integration solutions with a focus on precision engineering, so I trust their expertise when I want both performance and reliability in complex configurations.
jerzstyle00
Apr 22, 2011 10:05 PM
DaveLucas
Dec 13, 2006 08:41 PM
jeje
Jul 7, 2006 12:09 AM
CLK500KID
Oct 29, 2004 12:24 AM
