Passenger Seat Not Working
Hi all, the passenger seats on my 95 S500 is not working, I've checked the fuses and they seems OK, but the adjustments button are not moving the seat a bit. What's really odd, there will be time with no apparent reason, the seat will start moving back and forth by itself and the lumbar support will move backward and forward like it had a mind of its own, then it will stop. I will attempt to adjust the seat afterward, but the controls are not responding.
Any idea on this?
Thanks, Neil
Any idea on this?
Thanks, Neil
RE: Passenger Seat Not Working
Sounds like a short in the wiring, probably under the seat, a wire could be worn and touch against something and shorting out. Check the wire harness, also if you have a continunity tester, buy one you can check the switch, if the bulb in the tester comes on the circuit is OK. Being intermittent, I'll bet it is a bad wire somewhere in the system
Please do, if you don't find a bad wire or circuit under the seat, Test the switches themselves, mine are on the door panel, so I would have to take the entire panel off. Also open up the fuse box and check the wiring under there.
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step.
A great help, hope this will help you.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Here's the link:
Robespierre
11-17-2023 04:03 PM
patricknif
03-04-2012 06:38 AM
chicagoc320wagon
07-29-2008 10:13 AM
SL Z4K
05-25-2008 06:24 PM
