no sound from command system/radio, and cd changer not found in my 2000 s430/w220
Old Jan 29, 2009 | 08:13 PM
frk203's Avatar
Default no sound from command system/radio, and cd changer not found in my 2000 s430/w220
the battery died a couple weeks ago in my car,
now no sound comes from the radio/navigation the system turns on and i everything seems to work find except no sounds comes out, also when i switch to CD it says "cd changer not detected" or something like that.
i checked all the fuses under the hood and under the rear seat, specificly fuse 61 and 66 which are stated as the ones for the radio and CD changer, but all fuses are fine, so now im kind of lost
Old Feb 26, 2009 | 10:54 PM
S55kaj's Avatar
Cool did you find the problem?
frk203,
did you find the problem with your cd/radio no sound problem. I am experiencing the same issues. let me know if you found the problem.
kaj_5050@yahoo.com
Old Jul 17, 2009 | 09:42 PM
frk203's Avatar
Originally Posted by S55kaj
frk203,
kaj_5050@yahoo.com
sorry i never got to fixing it from reading around i found that the car uses fiber optic for the sound system and if any single device on the line (like cd changer, telephone module, etc..) goes bad then the whole system will not give out sound, you have to buy a special coupler and disconnect the devices one at a time to see which one is causing the problem.
oh also you can do a system test for the audio you have to set the radio to TAPE mode and click "mute+1+3" all at the same time and hold them for about 7 seconds and a special screen will appear
Old Aug 2, 2009 | 01:16 AM
vytamenc's Avatar
ok you have a problem in your d2b loop need to get codes from the comand center and find out what the problem is you need to find out what if your d2b loop is set up correctly. do you have a phone in your car with voice activation. you really need to go to the dealer and have them hook it up to the star and properly diagnosis it a star laptop is needed to figure this out. but in the mean time pull out your cd player and disconnect the fiberoptic loop from the changer and turn on the radio then plug the fiberoptic loop back in and see if everthing is working again.........
Old Sep 3, 2011 | 09:22 AM
Jenmar's Avatar
Has anyone gotten an answer to this? We too are experiencing audio problems after a battery failure. All worked fine until a new battery was installed and code put in, then no sound.
Old Jan 14, 2012 | 05:15 AM
mingch's Avatar
Default after cd changer removed, radio on without sound
I ask my mechanic to remove the cd changer, so it can be repaired by someone else. But now, radio is on without sound...did he just missed a connection, or will I just have to wait for cd changer to be put back?
thanks, Ming
Old Mar 9, 2012 | 11:10 AM
thomasrieger's Avatar
Same thing happened to me 2008c300 4matic. Dealer said that the aftermarket sub may be the cause and that would void my warranty I don't have a clue now what to do if you have any info that would be great T u
moetaz
May 3, 2011 06:35 AM
1sloturtle
Jan 19, 2009 09:33 PM
widmer
Oct 3, 2007 06:42 PM
milienstudio
Jul 7, 2006 12:01 AM
