carbon filter
3 filters in all.
2 paper filters (side by side) behind the passenger glove box. Need to remove glove box. 4 screws then pull. Need to disconnect glove box interior light and lock.
1 active charcoal filter above the "closing panel" above the front passenger footwell.
Need to remove about 3 screws then pull the closing panel towards you and then downwards. Get on your back inside the footwell. Look upwards and unclip the filter cover plate slide locks. Active charcoal filter pulls out. Quite expensive to replace. Unless you are a smoker i would suggest that replacing it is not good value.
Stuart
Stuart
