Cable to pc
Old Jul 12, 2006 | 08:30 AM
ryddan's Avatar
Default Cable to pc
Hi! I´m looking for a cable to connect my S420 to my laptop, and read/erase the error code. I have the program autotap, (or if you know some better prog). The MB Service want´s 150$ to do it. (Its insane!!!)
Newer i will pay so mutch many for that!
Have anybady some link to a sites who sale this cable. or any description to do a cable by my self.
Here is my problem.
https://mercedesforum.com/m_49022/tm.htm
Best regard
Johan Rydén
Sweden
Old Jul 12, 2006 | 09:41 AM
sleepwalker's Avatar
Default RE: Cable to pc
johan, your trans module got oil!
it's not suppose to have oil. must be dry.
i didn't notice your post lately.
Old Jul 12, 2006 | 09:46 AM
ryddan's Avatar
Thank you for your answer.
Ok then i dry it out. I hope it´s not broken.
But i can´t understand where the oil come from.
PS. I hope i messing with the right part. Her´s a picture:
Best regard
Johan Rydén
[IMG]local://upfiles/13148/5F1D8890F8D543FB86DC75333A1A6E73.jpg[/IMG]
Old Jul 12, 2006 | 12:38 PM
ryddan's Avatar
I have now open the control module and clean it with electronik spray and will also clean the connectors. Hope it will fix the problem. Darn bad i can´t erase the error code aswell so the car goes out from emergency mode. I realy need that cable.
Old Jul 14, 2006 | 05:37 PM
vytamenc's Avatar
THE OIL N YOUR ETC CONTROL UNIT CAME FROM YOUR TRANS ELECTRICAL CONNECTOR ON THE SIDE OF YOUR TRANS IT LEAKS AND GOES UP THE WIRES INTO THE TRANS CONTROL UNIT. SEE IT ALL THE TIME REPLACED THE TRANS 13 PIN CONNECTOR YOU CAN GET THEN ON E BAY ALSO GET A QUART OF FLUID AND A DIPSTICK TO ADJUST YOUR FLUID LEVEL WHEN YOUR DONE
Old Jul 17, 2006 | 09:15 AM
ryddan's Avatar
Great i will replace the trans 13 pin connector and fill up the oil level. need to order the oil and the dipstick aswell. Thank you so mutch for your answer. I have order a code reader from www.manualsunlimited.com. so now i can read/erase the codes.
Anyone have the part number for the 13 pin connector? I have find the other 2 part numbers.
Ebay is realy a mess trying to find anyting. (or a link)
I have also tryed www.getcoolparts.com and www.germanpartsonline.com
I also called my mb reseller and they as usual did not know anything, i said the cable from the transmission control module that goes in to the transmission. "dööh can you come in with the car and point it out was the answer i got" i dont want to drive at all with the car (i don´t know how mutch oil the transmission have leked"
It is:
Automatic transmission fluid:
001 989 21 03 10
722.6 Transmission dipstick:
140 589 15 21 00
Red locking clip
140 991 00 55
Thank you vytamenc, sleepwalker and all other who helped me. U are the best!!
Best regard
Johan Rydén
Sweden
jim60au
Oct 2, 2005 02:58 AM
paintarola
Feb 15, 2005 06:37 AM
Lugnut
Jul 4, 2004 02:53 PM
barmal
Jun 8, 2004 12:34 AM
nuwave2000
Apr 14, 2004 01:47 PM
