broken intake camshaft
Old Aug 2, 2007 | 08:48 PM
harasteh's Avatar
Default broken intake camshaft
I got 93 300se 3.2 and I changed the head gasket , didnot do the 3rd stage 90 deg. turn on head bolt and water got into oil and camshaft broke ,I noticed the chain was runing a bitloud,
I am trying to see what else I have damaged, any thought would be greatly appriciated, I notice when engine was running I didnot have any OIL presure and I thought may it was because I didnot connect the sensor properly. (I was wrong).
so not sure if I damaged the pistons or Valves or the hydrolic lifters.
thanks again
Old Aug 3, 2007 | 05:11 PM
NAZ's Avatar
NAZ
Default RE: broken intake camshaft
noo dis respect but pls check your head gasket if it was fitted correctly,90degress is not gonna make any difrrence cause thats the last stage you didnt do...........i dont thing the pistons will be damaged.................
Old Aug 3, 2007 | 05:14 PM
NAZ's Avatar
NAZ
sorry secondly, how did you set the timing chain tensoner,did you rest it or not?????????????
Old Aug 7, 2007 | 01:17 AM
harasteh's Avatar
I do not think you can put the gasket upside down, the are two long washer were the bolt go and with those in place , you can only put the gasket on one way. ( You are making me second guess now) I had half a gallon of water in the engine within few minutes and oil was coming out from the rear and front of the head.
The tensioner went on okay, just put the outer part first and pushed in the inner part. I noticed the tensioner does not go back once is pushed out.
is this normat. the inner spring circling the inner cyliner stops it from playing.
what do you think about the hydrolic valve adjuster.(not sure the proper name).?
thank you for your time.
Old Aug 9, 2007 | 01:36 AM
harasteh's Avatar
today I removed the broken cam and I noticed two of the intake valves on cycl#2 not moving back. any ideas what broke in there.
also noticed the cam on c280 1994 has same part # and 1993 3.2 300 se.
Question is , do they use same Head?
please help.
Old Jan 14, 2009 | 12:30 AM
mikehummer69's Avatar
replying to an older post.... Did you get er fixed yet? I have personal experience with what you described.
oldskoolbenz
Nov 17, 2010 06:06 PM
bigblockchev1
Mar 9, 2009 08:44 PM
CHICO500E
Jan 14, 2005 12:06 AM
Shakil
Jan 31, 2004 03:21 AM
jedelmann
Jan 8, 2004 03:18 PM
